Thread Rating:
  • 1
  • 2
  • 3
  • 4
  • 5
turbo conversio camper
Hi All,
I have a 1984 hymer camper on a MB 309D chassis,I am looking to uprate the power for steeper hills on motorways,not really for speed.Has anyone info on transplanting a OM 602 (ex sprinter) into this chassis or any other alternative,bearing in mind that the 617.95x is almost unavailable or costs too much to recondition.Is there a possibility to use hand controled variable boost.
Ps I am in Holland.
10-07-2009, 05:03 AM
Reply
winmutt Offline
#2
RE: turbo conversio camper
I have a L508D myself. The 602 should fit with some work. many have put the 60X's into the W123. Why so hard to get a 617.95x? I can't imagine shipping would be more than $1000.
10-07-2009, 05:33 AM
Website Find Reply
ForcedInduction Offline
#3
(10-07-2009, 05:03 AM)brianhymet Wrote: Is there a possibility to use hand controled variable boost.
It should be very easy using a system like the attached picture. Being in Holland you should have access to a wide selection of variable vane turbos.
The hand cable pulls on the vane lever and the actuator (a normal wastegate actuator) prevents boost from passing a safe level. Using VNT turbo with an electronic controller will allow finer control of pressure due to their longer vane control lever.
.jpg   vnt im0012168xa.jpg (Size: 69.8 KB / Downloads: 875)
(This post was last modified: 10-07-2009, 10:50 AM by ForcedInduction.)
10-07-2009, 10:48 AM
Find Reply
Brianhymet,
Living the Netherlands myself and having fitted a turbo and intercooler to my 1985 Hymer on MB 309d I am sure you'll be happy using the knowledge I gained.
I have fitted the turbo some 100.000 kms back and it is still running fine.
The OM617 in the 309d with turbo is something very different from the original. Problem with the 309d is you only have space for a turbo underneath the engine, lower than the oil pan. Meaning ........... no oil supply from the engine. I solved that one too!
03-28-2010, 12:22 PM
Reply
#5
(03-28-2010, 12:22 PM)Hymermofiel Wrote: Meaning ........... no oil supply from the engine. I solved that one too!
Scavenge pump? Belt or electrical?
03-28-2010, 11:54 PM
Find Reply
desmotre Offline
#6
(03-28-2010, 12:22 PM)Hymermofiel Wrote: Brianhymet,
Greetings, I have a T1 308 with a 2.3 l gasoline engine. The engine is not powerful enough to handle mountains and the weight of the camper. I have a 617910 engine from a 300D car (T1's were never sold in N/A) that I want to install. I would be interested in knowing more about your turbo conversion.
Thanks, Mike
Whitehorse, Yukon
05-02-2010, 12:51 PM
Find Reply
Forum Jump:
