Turbo
RE: Long project: ELITE. ELectronical Injection Timing Enhancement.
If I could find them for 50euro I will buy some...
most sertanly buy them, what is the thread for mercedes glow plugs in 0m613/om648?
Newer Mercedes om642ls is on the 200 bar region like the bmw 550/750d, if the new 400ps BMW is higher I have no information about, what the new engines with steel pistons have I do not know ether, but it would be interesting to now, but later engines I have no feeling that they are over engineered like 0m606/om613/om648.
I am thinking about 220bar with water injection since it brings peak combustion pressure down a bi,t but have at this moment no info about how much water is needed, that is why this is so interested, really good to get some feedback when playing around.
where you get that they should withstand 230 bar? om613 is original 145bar, if I am not wrong om648 is at 155bar, and how much they can take I do not know yet, and no steel piston from Mercedes will fit since bore is different
01-16-2018, 03:59 PM |
Turbo
01-17-2018, 03:42 PM |
Evgeniy1987
Well, to the left is an EDC pump (  ) assembled by Barrote a while ago (thanks again!)
I had a worn out timing device that i bought for 2€ on ebay, I disassembled it and had it milled down to a cilinder of 25mm outer diameter. So 25mm on the outside, splines for the pump shaft on the inside. Using a TranTorque ( http://www.fennerdrives.com/trantorque/) coupling, I attached the big flange to the pump.
Now, with a special metal coupling, I can attach the pump to the test bench, which contains the same thing as the red one on the right (I took a 2nd one for the foto)
The red thing is a torque (and rpm) measuring shaft. It is very precise. I can read it with the same device I used for the pressure measurement, so it can measure up to 150 kS/s .
So, If I go to 3000 pump-rpm, it does 50 per second. I can have up to 3 kS per revolution. So, over 360 degrees, I will have 3000 measurement points. Which is good, as we need to get nice, precise torque curves.
The outcome of the test will be shown to Harmonic Drive AG, who will help me with choosing the right harmonic drive.
(This post was last modified: 01-25-2018, 03:09 AM by Evgeniy1987.)
01-25-2018, 03:09 AM |
Turbo
what is so interesting with harmonic drive? I must be missing something.
I understand of it before that you where trying to create a electric controllable timing device?
what do you have that can sample so fast?
I want to get hold of something that can sample fast since I want to measure the pressure in the cylinder during all cycles in the engine.
There are system for this like below but it it is a lot of money even if I really need it for my tuning.
www.tfxengine.com
01-25-2018, 03:19 PM |
Evgeniy1987
(This post was last modified: 01-26-2018, 05:55 AM by Evgeniy1987.)
01-25-2018, 05:50 PM |
Evgeniy1987
(01-26-2018, 11:42 AM)baldur Wrote: I want an in line transducer like that for my engine dyno. Do they come rated for 10000RPM and 2000Nm?
Baldur,
The measurement shaft I have at work is up to 500 Nm rated KTR part. ... But KTR can offer much bigger stuff:
https://www.ktr.com/de/produkte/antriebs...esswellen/
https://www.ktr.com/de/produkte/antriebs...taflex-70/
Dataflex 70 would cut it: up to 3000Nm or 5000Nm. Whether it could go up to 10000 RPM - I don't know. I believe, the problem in that case is not the shaft, but the electronica amplifier.
But you probably won't bother building an amplifier that could
(This post was last modified: 01-28-2018, 10:37 AM by Evgeniy1987.)
01-28-2018, 10:37 AM |
