Thread Rating:
  • 1
  • 2
  • 3
  • 4
  • 5
602 flywheel
benzguy Offline
#1
602 flywheel
I'm going to do a conversion auto to manual and I need the flywheel there is one in EBay Germany that I like to buy but I asked the seller what clutch size does it takes and he does not know he only knows the part number which is 6020301305 does anybody on this forum knows my engine is 602 turbo so I need  a 9 inch clutch or bigger I have a flywheel from a 601 but it takes an 8 inch disc
08-17-2016, 08:55 AM
Find Reply
capflya Offline
Dreaming of a VNT
#2
RE: 602 flywheel
Not sure on that part number. I found a reference to a g-wagon with the 602/m102 motors and they used a 228mm (9") clutch so that one may be right. If the seller could take a pic of the other side it should be fairly obvious.
Have you considered one from 16v 190e? Thats what I used in my car. Looks like captruff (Jeff) has one on eBay right now. I got mine for $100 off car-part.com and just had to get it resurfaced. There is one listed now over at M&M there in Fontana but no price listed.
http://www.ebay.com/itm/Mercedes-190E-2-...2H&vxp=mtr
(This post was last modified: 08-23-2016, 01:23 AM by capflya.)
08-23-2016, 01:20 AM
Find Reply
NZScott Offline
HX30W 73/44mm
#3
RE: 602 flywheel
I don't know in the 60x case but with OM616/OM617+M110 the G wagens had different flywheels with larger clutches than the sedan version, and I bet the T1 vans were the same, so if you want a flywheel with a larger clutch avoid a sedan one
1978 300D, 373,000km
OM617.912 with a Holset HX30W, 7.5mm IP, 711.113 5 speed (awaiting certification to be legal...)
1977 300D (ex 280) 500,000km 'new' DD
08-23-2016, 02:52 AM
Find Reply
benzguy Offline
#4
RE: 602 flywheel
Tanks capflya for the tip I'm going to check the one M&M has in Fontana as I'm looking to spend around $150.00
08-23-2016, 05:05 AM
Find Reply
Petar Offline
7.5mm M pump
#5
RE: 602 flywheel
You could also machine the flywheel to fit a bigger clutch... At least that's my plan  Big Grin
300E clutch should be 240mm as far as i know.
08-23-2016, 12:36 PM
Find Reply
g wizz Offline
fuel oil junkie
#6
RE: 602 flywheel
is there such a thing as an upgraded pressure plate for the 8" clutch?
85 300d om603, 717, he 341, sch40 stainless manifold with prioritized 50mm external W/G (2"open dump), intercooled, intake manifold, full 3.5 stainless exhaust.
need to figure out a different trans cause its already pissed with only 5.5mm elements... then diff and suspension. but for now its daily as described above.
10-24-2018, 01:47 PM
Find Reply
benzguy Offline
#7
RE: 602 flywheel
Yes there is an upgraded pressure plate I remember reading about it on the 190rev website
10-24-2018, 06:32 PM
Find Reply
g wizz Offline
fuel oil junkie
#8
RE: 602 flywheel
(10-24-2018, 06:32 PM)benzguy Wrote: Yes there is an upgraded pressure plate I remember reading about it on the 190rev website
only ones i have found are for the larger clutches, not the tiny 8" one.
10-26-2018, 02:23 PM
Find Reply
serious_lee Offline
#9
RE: 602 flywheel
The one I got from a 2.5 190d was 8".  You can get a Sprinter flywheel which is 9.5"  Seems to be the preferred method for the 606 guys.
03-09-2019, 11:07 PM
Find Reply
Forum Jump:
