STD Other Projects Expiremental OM617 build
  • 3 Vote(s) - 4.67 Average
atypicalguy
11-16-2017, 09:43 PM #49
(10-27-2017, 07:59 AM)R-3350 Its been a while since i posted, but life has been busy lately so i haven't had much time to get a lot done on my car. got the 8mm Dieselmeken M pump in along with a carter P4601HP fuel pump and a much larger fuel filter to feed the beast. the M pump is set to 175cc and 5200rpm full load with full fuel cut probably somewhere around 6500-7500 rpm. im using the external alda to limit the output to somewhere around 120cc as thats as much as i can burn right now with the he221w set to 30psi. working on building the new exhaust manifold and plumbing to get a second turbo in as a set of compounds. it will be a while till thats done though as the manifold is going to be slow to make. im using some inconel 625 sheet i got to roll tubes, seam weld them and then pie cut and weld to get curves. once thats done i gotta finally decide what the LP turbo is going to be as there are at least 3 im considering right now. theres a lot more ideas i have been toying with in my head to test on this car but im limited in time and money right now so well see if i ever get around to them. all that being said the car is a blast to drive now it will slam you into the seat from a stop and i have broken the rear lose at 50 mph hitting the kick-down switch.
I am guessing your smoke factor and egt are a bit excessive with that turbo at 120cc. What sort of afr and air mass are you planning? And how are your intake temps with the current cooler setup?
atypicalguy
Messages In This Thread
Expiremental OM617 build - by R-3350 - 07-26-2016, 06:34 PM
RE: Expiremental OM617 build - by R-3350 - 07-27-2016, 06:16 PM
RE: Expiremental OM617 build - by raysorenson - 07-27-2016, 07:24 PM
RE: Expiremental OM617 build - by R-3350 - 07-27-2016, 07:49 PM
RE: Expiremental OM617 build - by raysorenson - 07-28-2016, 07:41 AM
RE: Expiremental OM617 build - by raysorenson - 07-28-2016, 08:01 AM
RE: Expiremental OM617 build - by R-3350 - 07-28-2016, 12:38 PM
RE: Expiremental OM617 build - by MFSuper90 - 07-29-2016, 06:11 AM
RE: Expiremental OM617 build - by R-3350 - 07-29-2016, 12:16 PM
RE: Expiremental OM617 build - by MFSuper90 - 07-29-2016, 04:13 PM
RE: Expiremental OM617 build - by R-3350 - 07-29-2016, 04:35 PM
RE: Expiremental OM617 build - by R-3350 - 07-29-2016, 06:24 PM
RE: Expiremental OM617 build - by R-3350 - 08-17-2016, 03:58 PM
RE: Expiremental OM617 build - by R-3350 - 08-22-2016, 06:41 PM
RE: Expiremental OM617 build - by R-3350 - 09-30-2016, 11:24 PM
RE: Expiremental OM617 build - by CRD4x4 - 10-01-2016, 09:10 AM
RE: Expiremental OM617 build - by R-3350 - 10-01-2016, 10:18 AM
RE: Expiremental OM617 build - by NZScott - 10-01-2016, 03:20 PM
RE: Expiremental OM617 build - by R-3350 - 10-03-2016, 10:53 PM
RE: Expiremental OM617 build - by SurfRodder - 10-04-2016, 12:24 AM
RE: Expiremental OM617 build - by MFSuper90 - 10-09-2016, 07:51 AM
RE: Expiremental OM617 build - by R-3350 - 10-09-2016, 08:57 AM
RE: Expiremental OM617 build - by NZScott - 10-09-2016, 05:38 PM
RE: Expiremental OM617 build - by R-3350 - 10-09-2016, 06:43 PM
RE: Expiremental OM617 build - by NZScott - 10-10-2016, 01:45 AM
RE: Expiremental OM617 build - by atypicalguy - 10-12-2016, 04:14 AM
RE: Expiremental OM617 build - by atypicalguy - 10-12-2016, 04:32 AM
RE: Expiremental OM617 build - by R-3350 - 10-12-2016, 06:54 AM
RE: Expiremental OM617 build - by atypicalguy - 10-12-2016, 05:16 PM
RE: Expiremental OM617 build - by atypicalguy - 10-12-2016, 08:32 AM
RE: Expiremental OM617 build - by R-3350 - 10-12-2016, 07:42 PM
RE: Expiremental OM617 build - by atypicalguy - 10-15-2016, 09:56 AM
RE: Expiremental OM617 build - by R-3350 - 10-20-2016, 09:33 PM
RE: Expiremental OM617 build - by NZScott - 10-21-2016, 12:34 AM
RE: Expiremental OM617 build - by R-3350 - 11-19-2016, 04:15 PM
RE: Expiremental OM617 build - by atypicalguy - 02-19-2018, 09:58 PM
RE: Expiremental OM617 build - by TKMad - 11-21-2016, 04:11 PM
RE: Expiremental OM617 build - by NZScott - 11-21-2016, 09:05 PM
RE: Expiremental OM617 build - by R-3350 - 11-21-2016, 09:30 PM
RE: Expiremental OM617 build - by NZScott - 11-22-2016, 01:07 AM
RE: Expiremental OM617 build - by MFSuper90 - 11-24-2016, 10:35 AM
RE: Expiremental OM617 build - by R-3350 - 11-24-2016, 12:01 PM
RE: Expiremental OM617 build - by Evenglass - 12-18-2016, 11:01 PM
RE: Expiremental OM617 build - by R-3350 - 12-19-2016, 10:29 PM
RE: Expiremental OM617 build - by DiseaselWeasel - 12-26-2016, 04:09 AM
RE: Expiremental OM617 build - by R-3350 - 06-08-2017, 10:46 PM
RE: Expiremental OM617 build - by R-3350 - 06-09-2017, 10:51 PM
RE: Expiremental OM617 build - by R-3350 - 10-27-2017, 07:59 AM
RE: Expiremental OM617 build - by atypicalguy - 10-29-2017, 08:54 PM
RE: Expiremental OM617 build - by atypicalguy - 11-16-2017, 09:43 PM
RE: Expiremental OM617 build - by R-3350 - 11-16-2017, 11:17 PM
RE: Expiremental OM617 build - by atypicalguy - 11-19-2017, 12:52 AM
RE: Expiremental OM617 build - by R-3350 - 11-19-2017, 02:59 AM
RE: Expiremental OM617 build - by atypicalguy - 11-21-2017, 09:25 PM
RE: Expiremental OM617 build - by MFSuper90 - 12-17-2017, 11:09 PM
RE: Expiremental OM617 build - by atypicalguy - 12-26-2017, 02:41 PM
RE: Expiremental OM617 build - by R-3350 - 02-19-2018, 10:43 PM
RE: Expiremental OM617 build - by R-3350 - 03-07-2018, 01:36 AM
RE: Expiremental OM617 build - by atypicalguy - 03-10-2018, 07:10 PM
RE: Expiremental OM617 build - by R-3350 - 03-11-2018, 12:53 AM
RE: Expiremental OM617 build - by atypicalguy - 03-13-2018, 06:37 AM
RE: Expiremental OM617 build - by R-3350 - 03-14-2018, 07:58 PM
RE: Expiremental OM617 build - by R-3350 - 01-10-2019, 12:43 PM
RE: Expiremental OM617 build - by NZScott - 01-10-2019, 03:05 PM
RE: Expiremental OM617 build - by atypicalguy - 03-02-2019, 07:31 AM
RE: Expiremental OM617 build - by NZScott - 03-02-2019, 03:41 PM
RE: Expiremental OM617 build - by R-3350 - 03-02-2019, 05:16 PM
RE: Expiremental OM617 build - by atypicalguy - 03-02-2019, 08:50 PM
RE: Expiremental OM617 build - by R-3350 - 03-02-2019, 10:46 PM
