Expiremental OM617 build
the exhaust housing is a visual copy of one i saw in ebay so were probably thinking of the same thing. i have a friend with a tormach pcnc 1100 nearby. i saw that housing on ebay and got the idea to run a band of steel tracing the exhaust housing perimeter with a v-band flange welded on.
as for the compounds im slowly doing research into what i would run. right now im thinking of a TD04HL-19T as the HP and maybe a GTX35 as the LP both flow large amounts of air at lower pressure ratios than the Holsets.
the intercooler is a work in progress once im happy with it ill post up the install photos and what i had to do to make it work. but i can say that im using a CXracing water to air intercooler its 12X11X4.5 with 3" inlet and outlet both on the same side. and im using a 30 row oil cooler as the heat exchanger for the coolant. i also dont have any AC or any other accessories taking up space i removed them a long time ago (i never use AC even on my families new Subaru i occasionally drive, why use it when you have windows).
the AFR im thinking of running is maybe around 15:1 this is lean enough to not smoke too much but doesn't need as much boost to maintain. if you read through JTY's build they discussed the optimal power AFR and Jeemu chimed in saying that they recorded 13:1 as optimal for the Mercedes IDI's also that they smoked light gray at that point and that solid black was around 10:1 or lower.
