full load increase electronic governor
Humm, idle suffering is not what I'll be looking forward to. I like the smoothness of tha car.
The switch might be a necessity then if you don't want any codes... The bugger would be to remember that its turned off when restarting the car, I am sure I would forget this often, turn the key and go...
I'll check if I got the right wires.
there is what was said earlier, its the proper numbers, is it?
1 - Red - Rack position (Side 1) ECU pin 21
6 - Green - Rack position (Common) ECU pin 14
7 - Black - Rack position (Side 2) ECU pin 39
All the best.
Olivier
