STD Tuning Engine Excessive (?) 300D engine clatter
Biocruzer
04-16-2016, 06:28 PM #1
Hi, all. After a nice long run the other day, I pulled up with a worrisome clatter (perhaps excessive even for an aged 300D) when I started from idle. When I start the engine cold, it sounds like a death rattle, when it warms up, it lessens, but disappears when the revs mount. It sounds (to my untrained ear) to be coming from the front of the engine, but I don't know? Suggestions so far have been cracked piston (no more blow-by from the oil filler than usual and engine is smooth) or a failed cam chain tensioner (chain recently replaced, and new top & tensioner guides, new tensioner, but no slack in chain), or a nailing injector(s). Is it possible to upload a 30-sec sound clip? Anyone out there had something similar?
Cheers
Graham
Biocruzer
Cheers
Graham
awsrock
300SDL / HX30 / 90cc
179
04-16-2016, 08:10 PM #2
Could be a loose crank pulley bolt
awsrock
Torkey
Dirty Diesel
220
04-16-2016, 08:28 PM #3
Have you checked the fuel system? I would look at that before suspecting crank problems.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
awsrock
179
04-17-2016, 12:07 AM #4
Forgot to add, I've had a loose crank pulley bolt on both my 603s, one my fault and one random. One rattled at idle and the other rattled at 3000rpm. It sounds pretty awful. Both times took it out and red threadlocker fixed it.
awsrock
SurfRodder
Jackass Extraordinaire
611
04-18-2016, 06:06 PM #5
motor mounts? usually it gets worse at speed thos...
OBK# 62
SurfRodder
OBK# 62
pryantcc
04-22-2016, 02:03 PM #6
It sounds like what you have is more extreme than this but I almost didn't buy a 606 donor car because of what I would have described as a knocking noise. It turned out to be the damper on the tensioner for the "fan belt"!
Just lever the top of it a bit with a screwdriver and see if the noise stops.
pryantcc
