STD Tuning Engine BOV for om617a
BOV for om617a
BOV for om617a
scrubs
03-24-2016, 12:20 PM #1
Any links or input for one?
1984 om617a with M-pump, Full IC, hybrid turbo, manual boost controller
scrubs
Dark Hawk
03-24-2016, 01:33 PM #2
No need for blow off valve on diesels
1984 300d 132k restormod project in the works
1985 300td 300k $600 off road adventure project
1999 land cruiser  235k, 33" mud tires, off road, towing, hauler
Dark Hawk
97e300
(its a 98 now)
109
03-24-2016, 10:23 PM #3
wrong section.
97e300
wrong section.
03-25-2016, 07:40 PM #4
Well the no need for blow off valves on diesels isn't totally correct. If you would put a big charger on it, such as a hx40, I guarentee it would surge while letting off under hard throttle, which can be prevented with a blowoff valve. But that just protects the turbo, it's not really needed
Sultzi
03-26-2016, 04:47 AM #5
Like mfsuper said. When you do example burnout and let the throttle off, it will surge pretty badly with bigger turbo so bov isn't totally useless.. But many would put it just for the sound of it, not to protect the turbo Big Grin
Sultzi
TurboTim
06-08-2016, 11:55 PM #6
And how are you guys setting up said BOV since there is no vacuum source?
76 300TD custom lots of stuff
TurboTim
Evgeniy1987
06-11-2016, 03:17 AM #7
(06-08-2016, 11:55 PM)TurboTim And how are you guys setting up said BOV since there is no vacuum source?
If it is really needed, you can get vacuum from the vacuum circuit and swith it with a solenoid, while you can control the solenoid with a switch at the throttle pedal.
It is possible, but a bit more complicated...
Evgeniy1987
TurboTim
06-11-2016, 06:09 AM #8
....Yeah you let me know how that works....
The better way I thought about doing but never tried since not really needed anyways was to just use EGP for the control line to just hold it shut.
TurboTim
Evgeniy1987
06-12-2016, 11:49 AM #9
[Image: bov_eplanation.jpg]
Something like this Smile
Evgeniy1987
TurboTim
06-12-2016, 04:38 PM #10
So what happens if you partially let off gas. Turbo still fluttering there.
TurboTim
TurboTim
06-12-2016, 04:39 PM #11
I do like the picture though!
TurboTim
TurboTim
06-12-2016, 04:40 PM #12
You know you want boost pressure to close the valve when on throttle though so you may want to add more stuff to your picture.
TurboTim
06-12-2016, 08:13 PM #13
Most guys use a control that has boost input on one side, and EGP on the other. Therefore when you chop the throttle boost overcomes EGP and opens the BOV.
I've never used one, but I've read several guys on comp D are using them
Evgeniy1987
06-13-2016, 04:49 AM #14
(06-12-2016, 04:40 PM)TurboTim You know you want boost pressure to close the valve when on throttle though so you may want to add more stuff to your picture.
Feel free to modify it  Big Grin
Evgeniy1987
