STD Maintenance General Dyno results
Dyno results
Dyno results
scrubs
12-08-2015, 10:11 AM #1
A bit back I'd found here the dyno results on a om617a with and without the M-pump and now cannot find it, could some assistance be asked for finding it again?
I made the statement that my om617 was running 250hp with the M-pump and BS was called, not having funds for a dyno found a thread here to support it
FWIW om617a, hybrid garrett T3-60mm, full intercooler,3" exhaust n little things currently forgotten but not much.
Thanks
scrubs
Thanks
scrubs
12-08-2015, 10:23 AM #2
Oh, 7.5 mm pump
scrubs
Oh, 7.5 mm pump
12-08-2015, 05:41 PM #3
I have a dyno sheet from my om617 that made 125 (150 at the crank) at the wheels with the mods in my sig.
Dark Hawk
03-03-2016, 01:52 AM #4
http://www.superturbodiesel.com/std/show...p?tid=3644
No dyno sheet but numbers, this guy did these on his 1984 300td
"I did a base line run on dyno every thing stock it did have a exhaust leak at flex pipe but not bad. It did 81.5 hp and 159 tq automatic to the wheels bone stock w/factory exhaust and air cleaner box.
I then removed exhaust from down pipe back, put 3"cold air intake to k&n filter, deleted egr, adjusted throttle linkage to make sure going wot and deleted all vacuum lines from injector pump it did 101 hp and 197 tq to the tire."
1984 300d 132k restormod project in the works
1985 300td 300k $600 off road adventure project
1999 land cruiser  235k, 33" mud tires, off road, towing, hauler
Dark Hawk
03-04-2016, 09:01 PM #5
Something to note is that every dyno will give different number.
One might say 140hp while another may say 120 on the same car
