STD Tuning Drivetrain getrag 717.404 in w124 300d turbo HELP!!!
PedroFerreira
12-02-2015, 03:08 PM #1
hello,next mounth i il start the conversion from automatic to manual in my w124 300d turbo.
i will use 717.404 gearbox from a w201 2.3 16v single fly well...
can i use the rest of the parts from a w124 CE300 24v with getrag whith dual fly well? like selector,clutch and brake pedal ,drive shaft,etc...
what is the max nm for  717.404?
thanks for help
PedroFerreira
thanks for help
Druk
12-02-2015, 05:34 PM #2
Is the gearbox you intend using the dog-leg Getrag box? The changer turret for the 'normal' gearbox won't  work with a dog-leg box and vice versa. This is because reverse and first/fifth gear are in different positions on each box.
Drive shaft for a manual box is also longer in the front half. The rear half and center bearing are the same. Clutch and brake pedal unit is a straight swop for the auto one. The clutch fluid is fed from the rear half of the brake cyl reservoir but it is better imho to provide a separate fluid reservoir.
You also need the manual gearbox rear crossmember.
This post was last modified: 12-02-2015, 05:40 PM by Druk.
Druk
hents99
12-03-2015, 02:41 AM #3
Flywheel and clutch must be from 16v. 24v dual mass Flywheel will not fit with 717.404 box.
www.elbe.ee - MB performance parts.
hents99
PedroFerreira
12-03-2015, 11:03 AM #4
yes im talking about dog leg geabox....
im think about to use :
-getrag dog leg from 190E 2.3 16v
-flywel from om603 n/a
-shift selector,drive shaft (wil be to short?),brake and clutch pedals and gearbox rear crossmember from a w124 CE 300-24V with getrag dog leg
the parts from CE work with gearbox from 190E?
PedroFerreira
Druk
12-03-2015, 11:40 AM #5
(12-03-2015, 11:03 AM)PedroFerreira yes im talking about dog leg geabox....
The 190e box is a 717.404 which has the long input shaft and should be fine with the SM flywheel but not the DM.
The 124 box is a 717.450 which has a short input and needs the DM flywheel although whether they use the same casing and gearchange turret or not I don't know for certain but probably. If you have the manual driveshaft it should fit. It's the auto one that shorter.
This post was last modified: 12-03-2015, 11:42 AM by Druk.
Druk
PedroFerreira
12-24-2015, 08:16 AM #6
what single mass fly wel can i use?
PedroFerreira
12-24-2015, 10:32 AM #7
Any of them that will bolt to the crank.
PedroFerreira
12-24-2015, 10:35 AM #8
yes but i whant to go to 300hp..230mm is ok whith reinforced clutch?
PedroFerreira
benzguy
12-24-2015, 06:50 PM #9
The bigger the clutch the better if you can find the flywheel from an 86 300E that one takes a 9.5" clutch disc
benzguy
PedroFerreira
12-25-2015, 08:08 AM #10
and that is single mass? what years from 300E had single mass flywheel?
PedroFerreira
ccrelan
12-25-2015, 08:28 AM #11
1986-1988 300e USA cars and also pre 1990 190E 2.6 USA cars were single mass
ccrelan
benzguy
12-25-2015, 06:12 PM #12
(12-25-2015, 08:08 AM)PedroFerreira and that is single mass? what years from 300E had single mass flywheel?
Yes that is a single mass flywheel. The 190 with a 2.6 engine takes a smaller disc 9 inch
benzguy
PedroFerreira
12-25-2015, 06:15 PM #13
european models from 300e and 190 2.6 dont use single mass?
PedroFerreira
PedroFerreira
01-04-2016, 03:12 PM #14
what drive shaft can i use on that gearbox? from 300d whith manual gearbox will work?
PedroFerreira
uli124125
01-05-2016, 02:14 PM #15
why use the expensive and not for high torque made 16 tranny?
if you use the 717.450 you can use the Spinter single mass set and you have a tranny that works better and which you can fix again if it is broken
uli124125
swampmonkey
hx40 super
280
01-11-2016, 10:44 AM #16
(01-05-2016, 02:14 PM)uli124125 why use the expensive and not for high torque made 16 tranny?
as far as i know its the oposite way around, aqcuantances that broke three 717.450 with 350hp something, (unknown torque) but not heaploads anyhow, while people beat the 717.404 a lot harder. A LOT
what makes the 717.450 more easy to fix btw? availability in parts?
This post was last modified: 01-11-2016, 10:45 AM by swampmonkey.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
PedroFerreira
01-12-2016, 11:00 AM #17
some one can help me whit drive shaft? what can i use?
PedroFerreira
