Bmw / cummins camplate swap help
As long as you are not blowing huge amounts of white smoke you should be ok. You can also try to swap the nozzels between rotorhead and lines to the injectors. These nozzles have a extra pre injection mechanism. I ran my pump at 0,92mm pre injection cummins head and plate no problem. Bigger quantity in shorter time will make such a noise you shouldn't be able to talk with the hood open.
