Baby Holset Turbo Conversion build thread
(10-30-2016, 10:52 PM)What did you end up doing with your clutch? Did you fit a 240mm? I\m in the same boat, my 215mm can't handle the input torque of the 7.5mm pump and hx30! I am considering modding the flywheel to accommodate the larger PP from the sachs 76 5NZScott 711.113, or G 1/18-5/4,7. Used in T1 vans/trucks. 711.117 is the G wagen version. 4.695 1st gear and 0.806 5th. Still using my 4 speed gearshift but had to bend the tab that presses the reverse switch so it wouldn't turn the reverse lights on in 1st gear, which is below reverse dogleg style.
1st and 2nd are unscynchronised, (meant to use 2nd as first most of the time) so it's not really ideal for a sedan but meh, got my overdrive
