Hi ya'll. Got a free 79 300td....
(11-05-2015, 10:41 AM)bicyclewrenchSame pump, yes. But even when professionally set they only put out 60cc or something around that. Will it be better than NA? More than you can imagine! But if you are looking for over 140-150hp, an upgraded injection pump is a must.(11-04-2015, 11:17 PM)MFSuper90 We turbo NA tractor engines all the time for pullers. It's not a big deal. Go for it! If you push too much boost you might blow a head gasket, but your stock pump won't push enough fuel for that unless your turbo is way too small
That's what I'm trying to find out. So you're saying the pump can't be adjusted for enough fuel? Is it the same pump as on the .952?
