87 300SDL
87 300SDL
So this S200G I have, I will likely use it but was wondering if anyone else out there has seen one. I know Keino on here has it, but have not heard of anyone else. He claims it starts working around 1700 rpm on his 617 with 130cc. I have way less fuel but have the advantage of another cylinder. I wouldn't mind a bit later boost, my off idle torque is good enough as is (ran without ALDA connected for a few months) I'm hoping that the better manifold will make up for any later boost, obviously I cannot use the US manifold with this turbo...I'm lucky I fit the HX30 in there!
Anyway, It has a twin scroll housing, but I don't know what cm it is. The interesting thing is that each scroll (?) seems to be a different size...drastically. Is that how all twin scrolls are? The casting line down the middle is the divider for each inlet, for reference
Normally I would say this would be too much turbo for me, but the turbine isn't too much bigger than the HX30 I have (56/70 vs 52/65) and while the housing is pretty big, it might spool up decently. I am going to try it out and I'll report back. If it is too big, I might just get myself a bigger pump
Here is the turbine, seems more open than the one on the HX30
