87 300SDL
87 300SDL
It's a KKK, wastegate has not been adjusted. I'm probably at or near the 180hp mark. There's just a brown haze from the tailpipe at WOT. It will blow black smoke at the boost transition RPM range, then stops. Torque peak is probably at 3500 rpm then falls off a good bit past 4000. Much more torque off boost too. It's a great car as-is now.
The 7.5mm elements aren't expensive and labor is the same to have either elements installed. The 7.5 elements will have shorter injection duration, which is good for power and lower EGT's. The 7.5mm elements probably make idle louder than 6mm.
Yes, Diesel Injection Services did mine. No complaints.
