STD Tuning Engine Engine for land speed racing
Turborick
09-08-2009, 01:02 PM #1
Hey guys looking at possibly going after some diesel land speed records
and would like to know some dimensions for a 2L and 3L engine. not sure what models. What kind of power can be made with these engines?
they need to go 5 miles at full power so they need to be durable.
we can use any fuel or power adders we want propane, nitrous, water what ever. right now we are just looking at what's out there.
Thanks Rick
Turborick
Thanks Rick
09-08-2009, 01:20 PM #2
om60x is good for 400 or so. Kind of an odd choice for an engine I would think?
Turborick
09-08-2009, 01:34 PM #3
Thanks for the Reply winmutt
what would you think would be a better choice for a 2L and a 3L engine?
Turborick
09-08-2009, 01:43 PM #4
JATO rocket ! Honestly I don't know. Certainly stay away from the om61x... What do people normally use for this kind of thing?
Turborick
09-08-2009, 02:03 PM #5
We've never ran a diesel in our streamliner but most people have much larger streamliners that can accommodate larger engines but on the flip side need much more power to go fast. We have gone 360mph with just 550hp, it takes other streamliners 1000hp or more to go the same speed. I haven't seen any diesels that have run at bonneville that would fit our chassis, mostly cummins, duramax and JCB
Turborick
09-08-2009, 02:14 PM #6
You'll be in for a tough battle and a lot of money. The last speed record attempt used a pair of 750hp 4-cylinder industrial diesels.
A pair of OM606's at ~400hp could stand that kind of run. I haven't seen many Finns do much more than drag racing or drifting, so endurance is questionable.
[Image: 5548_22040612636.jpg]
This post was last modified: 09-08-2009, 02:15 PM by ForcedInduction.
Turborick
09-08-2009, 03:42 PM #7
so you think a om606 can run 400hp. at what rpm? how long is the engine from bell housing to end of harmonic balancer?
how tall is it from crank centerline to valve cover?
Turborick
09-08-2009, 03:45 PM #8
(09-08-2009, 03:42 PM)Turborick so you think a om606 can run 400hp. at what rpm?
4500-5000rpm would be good for endurance since it within the stock operating range, but Finns have been known to revv around 6-7000rpm.
Quote:how long is the engine from bell housing to end of harmonic balancer?
That I don't know. krashappy is online now, he could measure his 606 for you.
606Power
09-09-2009, 08:49 AM #9
Take a look at:
http://www.youtube.com/watch?v=Yv2aX58lx2Q
and
http://www.youtube.com/watch?v=Skam-aeCFOY
It is supposed to be able to rev to 9K rpms, about 90 psi of boost @ the manifold and produce 750 hp, which, is the minimum for longevity and daily use according to them. It appears to idle with about 1/2 a Bar as well.
I can measure the 606 when I get home from work, if someone does not beat me to it.
(09-08-2009, 03:45 PM)ForcedInduction
606Power
Take a look at:
and
09-09-2009, 10:48 AM #10
(09-09-2009, 08:49 AM)606Power It is supposed to be able to rev to 9K rpms, about 90 psi of boost @ the manifold and produce 750 hp, which, is the minimum for longevity and daily use according to them. It appears to idle with about 1/2 a Bar as well.
I bet they have more than the usual ~$10k into it though. Big Grin
606Power
09-09-2009, 11:05 AM #11
Indeed! I would love to know more of what is in it as well Idea
Also, a nice vid:
http://www.youtube.com/watch?v=7xnl_yAD4...re=related
The timing sounds really advanced, but it might be necessary so the timing device can still advance at higher revs.
606Power
Also, a nice vid:
09-09-2009, 11:10 AM #12
Using the torch to get heat for traction is a nice touch.
09-09-2009, 12:21 PM #13
Anyone else notice the camera man being sucked into the vortex of that turbo? LOL what do they have in there?
606Power
09-10-2009, 02:12 PM #14
So, the 606 in full dress measures in at about 30.5" from the crank pulley to the bellhousing. Add about 1.25" for the starter nose bearing support.
The crank centerline to the valve cover is about 19", and about 8" from the centerline to the bottom of the stock oil pan.
606Power
