W124 build
W124 build
(03-18-2016, 11:25 AM)whipplem104 Up and tuning the boost control. Here is a snapshot of boost control and EGT monitoring. Still dialing it in.
Valve spring sample came back in and looks like it is going to work out. Double spring with titanium retainers and 67 seat pressure and 177 at 10mm lift. They also have no bind in the head so the valve seals are the 1st interference. Should be able to get just shy of 13mm of lift. I would say 11.5 would still be safe. You could machine the valve guides and maybe drop the seal a bit.
