STD Tuning Engine NonTrapox manifold, hits water pump outlet?
Whizbang
02-17-2015, 08:46 PM #1
w124 om603
In the middle of this turbo swap disaster, and it seems the non trap ox manifold hits the water outlet pipe leading to what is probably the heater core. Is there a different water outlet assembly for this? Is it something source able here in the states? Probably off the 92-93 300SD/94-95 S350?
Also id like to get my hands on the euro, or the 92-93 300SD/94-95 S350  om603 turbo assembly to make this install easier if anyone has one for sale.
This post was last modified: 02-17-2015, 08:47 PM by Whizbang.
Whizbang
w124 om603
02-18-2015, 10:53 AM #2
The part from the 602 should work too. I priced it at around 110-150 a while back. Too much.
If were going to install one of these, I would cut and weld or look in a junk yard for a used replacement.
Whizbang
02-19-2015, 01:21 PM #3
Looks like the pipe is just a pushed in o ring seal
Whizbang
02-19-2015, 02:47 PM #4
It is. Smile Any OM601/602/603 should fit. Smile Might still be worth getting the complete waterpump housing from a 350 engine - this does fit the 72mm impeller water pump (stock is 69mm) for better cooling Smile
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
