11-13-2018, 04:04 PM
#172
(11-13-2018, 11:07 AM)whipplem104 Is it your twin setup that is causing you to be down so much on HP. You use to make a lot more?
It's still reasonable 600hp from engine with new dyno results but yes on graph it's little less than it was with single turbo. As I said we had whole new dyno setup now with new dyno software and for the first time we used dyno roll brakes to make big turbo spoolup properly. Also I was using 2.65 diff for the first time. Different gear ratios and different dyno settings can make up big differences in numbers so it's hard to say if it has more or less power than with single hx52 but it's definitely faster and feels more powerful. In 2016 with single hx52 it made 408kw and 858nm from wheels. This time with new intake it made 382kw and 767nm but with old intake that I also used with single hx52 it made only 340kw but even with that it was faster this year. For example with singe turbo my best 1/4 mile was 12.9 192kph but now with slow start and with same ET it makes more kph. It has to be way slower than ET 12.9 to make speed as slow as 192kph and even with old intake manifold it made 199kph this year. It has a lot wider and useful rpm range now.
But main thing with 2 turbo setup is that driving comfort and engine dynamics is from different dimension compared to single hx52, it's hard to explain with words how much more refined it is now. Single hx52 and auto box is completely useless on street but now it drives like stock car without one minute turbo lag.
It could be much faster on 1/4 mile but I want to keep it as sleeper and not to rip out interior.
Graph from 2016 with single hx52 and 8mm mech pump.
