W202 OM606 GT2359v+Pro52
The finished manifold looks awesome man! Perfect filter location too, your work is very clean, giving me inspiration to work on mine.
Thank you for also putting the fuel pump pictures in here, it really helps to see it all mounted in the engine bay.
Did you drill the camshaft/sprocket with it inside the engine? I'm not sure how you can check without starting the car and seeing what the timing is, i plan to put the pin in mine when i remove the head and have the camshaft out.
