W202 OM606 GT2359v+Pro52
It's pre-facelift, so it came with 722.4. All parts from 2.2d are ridiculously tiny so I also changed propshaft, differential and driveshafts. Front brakes have solid disks, not even air ventilated, I did't know MB even had those.
First I used 604 mounting arms but there was no room for cooling fan, then I changed to 606 arms and now it fits perfectly. Gearbox mounting bracket is modified, propshaft is from w210 and shortened, diff is from w124 and driveshafts are from w210 and shortened.
606 arm on left and 604 arm on right
Propshafts, you can see the differences.
Longer power steering hoses
w210 300td 2.87, W124 3.07 ASD which I use at the moment and tiny 2.2d 3.27
Some new parts
Avantgarde springs from w210
New nozzles
3" exhaust and HX35 super, turbo is sold for now because it was too small.
Cooler 2.5" hoses are from local truck parts store.
First I used gearbox from 300td but 4th and 5th gear started to slip, so I bought 2005 w211 320cdi gearbox and swapped the bellhousing. And yes, I6 320cdi engine has different housing, it was surprise to me also, 220cdi and 270cdi is the same as 606.
3" exhaust finished, tried different zink based coating paints.
And some smaller modifications, like little pipe in cylinder head, ordered 604 one from mb dealer.
606 has long pipe with rubber sealing
And 604 pipe pressed in.
And it goes in. Exhaust and inlet manifolds were stock, just made the flange to fit bigger turbo to genuine manifold.
Latest purchase was gearbox controller from olefejer.
