(02-08-2015, 03:46 AM)sassparilla_kid Druk does your driveshaft have the center u-joint like stock or did you eliminate it?
Eliminated it. Gone. And the reason I had to do this is because my installation is way off alignment, maybe by as much as 1". What the driveshaft engineer did say (and he did a home visit to inspect) was that because of the length of shaft involved an extra wall thickness and dia pipe was required. Additional to that, the thing is stuffed full with some sort of cardboard which acts as an anti-resonator or vibration damper.
I did wonder at the spec of Ray's pipe and whether that might be at the root of his vibration problem
