STD Tuning Engine Garrett 712120 VNT Hella 6NW 008 412 actuator.
  • 2 Vote(s) - 5 Average
300SD81
11-21-2009, 03:32 AM #57
(11-19-2009, 03:35 PM)cell this is awesome work guys!
after the holiday season I'll definitely be looking to put an electronically actuated VNT into the GM Benz. If your project hasn't been completed by then, I'd be happy to help out (I have a good bit atmel and arduino experience).
the next big project I'd like to work on is a fly-by-wire accelerator with a force-feedback pedal. I'd like to make my IP rack actuated by a servo, and replace the function of the ALDA with force-feedback. The pedal would offer no resistance until you reach a point where the microcontroller decides you're about to start making black smoke, at which point the pedal pushes back against you. The key here is that the force-feedback would be weak enough that if you mashed the pedal, you could overcome it. This would allow you to inject additional fuel in emergency situations, while remaining environmentally friendly in day-to-day driving.
so of course, having an arduino-controlled VNT would complement that system nicely!
Definitely sounds like an interesting project, keep us posted Smile Are you planning to just replace the throttle linkage or the actual pump governor?? I'd like to do a completely electronically controlled IP some day..but definitely don't feel like I'm good enough to do it yet. microcontroller crash = engine go boom...
V3, FINAL of the turbo controller is now complete Smile had to deal with some overheating of the voltage regulator on V2, and make some provision to mount it in a case... V2 was laid out to fit on a scrap PCB and I didn't have enough room for mounting holes.
I got a new sensor board laid out and parts ordered as well, so I can ditch the USB interface and make everything ethernet.. ECU is next, as soon as Microchip starts shipping samples of the PIC32MX795F512H (80MHz, 128K RAM, Ethernet.. Big Grin Should be more than enough, I hope..)
This post was last modified: 11-21-2009, 03:37 AM by 300SD81.
Ich liebe meine Autos!
300SD81
Messages In This Thread
Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 08-18-2009, 09:13 AM
RE: electronic actuator? - by Tymbrymi - 08-25-2009, 01:15 PM
RE: electronic actuator? - by tomnik - 08-27-2009, 07:15 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 09:01 AM
RE: electronic actuator? - by Tymbrymi - 09-01-2009, 09:28 AM
RE: electronic actuator? - by winmutt - 09-01-2009, 03:51 PM
RE: electronic actuator? - by tomnik - 09-01-2009, 09:49 AM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 08:31 AM
RE: electronic actuator? - by winmutt - 09-03-2009, 01:18 PM
RE: electronic actuator? - by Tymbrymi - 09-03-2009, 01:32 PM
RE: electronic actuator? - by winmutt - 09-03-2009, 02:23 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 08:21 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 11:30 AM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 03:17 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-04-2009, 12:29 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-04-2009, 01:36 PM
RE: Garrett VNT Hella actuator. - by winmutt - 09-05-2009, 10:26 AM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 09-05-2009, 10:14 PM
RE: Garrett VNT Hella actuator. - by winmutt - 10-22-2009, 11:22 PM
RE: Garrett VNT Hella actuator. - by Tymbrymi - 10-23-2009, 09:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-05-2009, 10:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 10:12 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-08-2009, 02:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 09-09-2009, 08:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-09-2009, 10:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-10-2009, 08:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 09-14-2009, 04:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-19-2009, 02:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-20-2009, 10:51 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-23-2009, 01:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-23-2009, 03:51 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-27-2009, 08:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-28-2009, 09:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-28-2009, 10:34 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-27-2009, 11:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 12:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 02:12 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 05:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-29-2009, 12:38 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 10-29-2009, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by piledriver - 10-29-2009, 08:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 10-29-2009, 09:29 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 10-30-2009, 08:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-02-2009, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-03-2009, 03:48 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-03-2009, 04:01 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 11-05-2009, 10:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-04-2009, 04:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-04-2009, 09:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-05-2009, 12:26 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-05-2009, 01:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-06-2009, 04:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-12-2010, 10:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 01-12-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by muuris - 01-13-2010, 05:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-08-2009, 03:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 11-09-2009, 02:40 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-14-2009, 05:00 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 11-19-2009, 03:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 11-21-2009, 03:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 11-21-2009, 05:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by nockter - 12-05-2009, 01:40 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-07-2009, 02:08 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by lars - 12-08-2009, 05:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2009, 11:21 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-08-2009, 07:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 12-14-2009, 03:28 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-12-2010, 04:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by kmaser - 01-12-2010, 05:52 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:09 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Kiwibacon - 01-23-2010, 08:23 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 01-23-2010, 08:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 01-26-2010, 04:02 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-07-2010, 07:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 02-08-2010, 10:41 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by ForcedInduction - 02-11-2010, 02:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 02-18-2010, 10:36 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by cell - 02-19-2010, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 03-30-2010, 01:19 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by racerxoffl - 10-19-2010, 11:39 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by TB206HDI - 09-23-2010, 02:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 09-23-2010, 02:24 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 09-23-2010, 03:05 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by dgn555 - 10-03-2010, 06:53 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-01-2010, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-01-2010, 10:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 02:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 07:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-02-2010, 09:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-02-2010, 10:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Tymbrymi - 12-02-2010, 12:31 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-08-2010, 06:31 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-01-2010, 10:53 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-06-2010, 01:32 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Captain America - 12-07-2010, 04:07 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-08-2010, 10:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-09-2010, 02:24 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-09-2010, 11:32 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-15-2010, 03:22 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 12-15-2010, 09:14 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-17-2010, 03:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-15-2011, 07:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-15-2011, 08:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-16-2011, 02:44 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 04-21-2011, 03:38 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-15-2010, 09:10 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 11:49 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 11:55 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 03:43 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-16-2010, 06:50 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-16-2010, 08:35 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300D50 - 12-17-2010, 11:03 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-17-2010, 11:09 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 12-20-2010, 10:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-16-2011, 10:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 01-18-2011, 02:37 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Biohazard - 01-18-2011, 09:52 AM
It's the "post your actuator guts" thread now - by aaa - 04-15-2011, 02:41 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-17-2011, 11:25 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 01:30 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by tomnik - 04-18-2011, 02:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-18-2011, 02:59 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-18-2011, 11:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-18-2011, 09:29 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-19-2011, 02:33 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by 300SD81 - 04-19-2011, 09:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-20-2011, 08:39 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 04-20-2011, 08:48 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Pali - 04-21-2011, 03:01 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-01-2011, 04:07 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by winmutt - 07-01-2011, 03:57 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 07-05-2011, 02:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-25-2012, 02:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-20-2012, 04:20 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-29-2012, 11:16 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-29-2012, 02:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by majesty78 - 01-30-2012, 04:21 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Rub87 - 01-30-2012, 05:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 01-30-2012, 01:45 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 02-20-2012, 11:13 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 02-22-2012, 05:42 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-17-2012, 07:03 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 09-25-2012, 03:46 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 07-18-2012, 05:25 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by raysorenson - 07-18-2012, 10:56 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 10-09-2013, 08:58 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-04-2013, 06:22 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by janus - 11-05-2013, 01:47 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by pemtek - 11-05-2013, 03:49 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-10-2014, 02:06 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Iangiulu - 07-12-2014, 02:42 PM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by Darqs - 12-18-2014, 03:06 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by antonmies - 01-23-2015, 06:43 AM
RE: Garrett 712120 VNT Hella 6NW 008 412 actuator. - by HoleshotHolset - 04-15-2015, 10:37 AM
 9 Guest(s)
 9 Guest(s)
