STD Tuning Engine fitting m pump to om605
gary andrews
4x4 builder
48
01-14-2015, 02:31 PM #1
just fitted a m pump to a 605 which is going in a discovery 2 and got to sort fuel lines,wondering how much you need of old system i.e. fuel heater thermostat etc .is there a simple way to set up that wouldn't give any grief
c250 std at mo
gary andrews
c250 std at mo
01-14-2015, 02:54 PM #2
hy there,
depending on how much time and Money you have,
no Money and time : install M pump with lift pump, pay atention to air leaks in piping! use a whashable type (Metal)screen before lift pump.(or use the MB screen at MB 605 fuel filter assy) lift pump to filter , return lines from filter and IP to tank.
Plenty of time and Money: tank to electrical booster pump(BMW type are the best, able to 5BAR) use a press regulator valve set at 3BAR max. line goes to engine fuel heat exchanger at cyl head. then MB fue filter assy and MB stock instalation. use a overide swich for booster pump.
regards good luck.
hy there,
regards good luck.
