STD Other Projects W202 Wagon build thread - *NOW OM606*
  • 2 Vote(s) - 4.5 Average
Pages (3): Previous 1 2 3
05-17-2017, 05:17 PM #101
Working on the oil cooler install. Not sure if it is a good idea or not, might go for a matching cooler like the mocal ATF one by the OSF wheel..
[Image: oil%20cooler%201.jpg]
[Image: oil%20cooler%203.jpg]
Does fit honest..
Does fit honest..
05-17-2017, 05:18 PM #102
Fitted 1.5 bar pressure relief banjo, with stiffer lift pump spring, not sure if I am happy with it.
[Image: Banjo.jpg]
Stock banjo is quite long so I had to get my friend HughF to make me an adapterizor:
[Image: IP%20return%20banjo.jpg]
Made a little drawing for him
[Image: IP%20overflow%20banjo%20adapter_1.jpg]
This post was last modified: 05-17-2017, 05:25 PM by Hario'.
[Image: Banjo.jpg]
05-17-2017, 05:22 PM #103
Made some better lowering brackets for the ARB clearance
[Image: arb%20bracket.jpg]
05-17-2017, 05:29 PM #104
Remote Bosch filter housing, 8mm lines but 10mm from filter head to the IP because that's what the fitting from hents99 was threaded for (m14).
Need to wire up the heater element and thermostat switch on that filter head. Does the thermostat switch operate a relay or is it 5-10A capable? Don't know.
[Image: new%20fuel%20system%204.jpg]
This post was last modified: 05-17-2017, 05:30 PM by Hario'.
bruno_pinho
05-18-2017, 12:44 PM #105
With this connection at the pump the car turns off as soon as you turn the key?
bruno_pinho
hooblah
05-19-2017, 08:11 PM #106
No. In theory it will with one of Sean Treacy's maps. But that's yet to be tested.
hooblah
05-22-2017, 09:02 AM #107
(05-19-2017, 08:11 PM)hooblah No. In theory it will with one of Sean Treacy's maps. But that's yet to be tested.
I have one of seanyt's maps and it still runs on..
Thinking about it, when I fit the electric fuel pump which will cut immediately with ignition switched off, maybe that will stop the run-on?
hooblah
05-23-2017, 12:49 PM #108
I've got the an electric pump and it runs on. Haven't fitted Sean's chip yet.
hooblah
hooblah
05-31-2017, 05:06 PM #109
Fitted Sean's stage 1 chips and it still runs on.
hooblah
seanyt
is300d He351ve
279
06-01-2017, 07:45 AM #110
What pressure are you both running in your FPR.
I still just use the stock banjo bolt with 0.5bar spring and it shuts off straight away.
seanyt
06-01-2017, 11:36 AM #111
Mine ran on before I fitted seanyt's ECU, I think its SOV delete related.
Cut apart the manifold again and re-tacked it so it actually fits as per..
[Image: mani%20build%208_1.jpg]
[Image: mani%20build%206.jpg]
All pipes fitted much tighter to the block, especially #5&6 because of steering box clearance on RHD.
[Image: mani%20build%207.jpg]
This post was last modified: 06-01-2017, 11:39 AM by Hario'.
06-25-2017, 04:33 AM #112
Had to go a bit loggy on #5 but I am pleased with it.
'Just' have to seam weld it all now..
[Image: runner%205.jpg]
