Thread Rating:
  • 2 Vote(s) - 4.5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
W202 Wagon build thread - *NOW OM606*
erx Online
w202 om606
RE: W202 Wagon build thread - *NOW OM606*
(02-21-2017, 04:38 AM)Hario Wrote: Shit it still runs the same after rebuilt elements fitted, you think it needs a pump swap? I do have a spare EDC pump from a friend so you think I should try that next? As prechambers are good, injectors are good, and the lines are clear, the only bad fuelling will now be coming from the pump..
If engine mechanical is ok then you can try to change delivery valves first. If it's lumpy on idle then loosen injector lines one by one and try to make clear which cylinders are not working.
02-21-2017, 05:14 PM
Find Reply
Hario' Offline
I replaced the DV seals first several months ago and no change. I think you will be right with your diagnosis of an element/plunger fault.
I fitted a spare EDC IP and it had a stocky rack and one seized plunger also!  So now I am waiting for the post to give me another IP I just bought. 3rd time lucky...
Thanks for your guidance!!
(This post was last modified: 04-18-2017, 11:14 AM by Hario'.)
Find Reply
Forum Jump:
Users browsing this thread: Rossey, 1 Guest(s)
