W202 Wagon build thread - *NOW OM606*
(02-19-2017, 03:57 PM)HarioLet's hope the best but if it's still lumpy then looking pictures on 1st page my guess is dust in element gallery and scratched elements/valve seats. This hole on picture is going straight to element's gallery and if tiny dust particle is stuck in element or valve seat then it's enough to ruin pump. If it was stored and transported like on picture then more or less stuff fell in for sure. All fittings after fuel filter need extra attention because all that's going in from there is going straight to pump.(02-19-2017, 11:13 AM)erx(02-19-2017, 10:06 AM)Hario Ok thank you for the info, I got rebuilt injectors for a steal @ £25gbp each so I have not checked mine yet, my friend has a pop tester so I will check my old ones to see spray pattern and pressure to confirm they are bad. Will rebuild them @150bar pop then swap back also.
It is my daily so have to be like this unfortunately. Pump timing not moved from when I first got engine when it ran sweet, so I don't suspect, and it is splined to can't have slipped.
Even when warm it runs lumpy, idles fine after a hard run then deteriorates - Presumably from prechambers and injectors cooling down and then bad fuel atomisation is not hidden anymore by heat evaporating un-atomised fuel.,
Should run fine now but flattened battery from having music playing for 2 days during the swap lol, tbc..
Cheers,
Engine worked fine when you first got it and suddenly injectors and prechambers are not working. It doesn't make sense, this kind of things don't happen over night. Also there's no such thing as prechamber cooling down when engine warm and working. I belive you have other problem like maybe air in fuel system, dust in pump delivery valves, if you take off injector lines or any other fuel system parts then you have to keep it extremely clean.
No I mean it deteriorated over the 20k miles of my ownership, replaced DV washers and O-rings with no change, so we will see in the morning if it is fixed now,
Cheers,
