STD Tuning Engine what are the symptoms of a bad ip?
NapaBavarian
06-20-2014, 05:39 PM #1
I have a couple cars that are giving me fits at the moment, what would indicate that the ip is to blame?
NapaBavarian
Torkey
Dirty Diesel
220
06-20-2014, 07:02 PM #2
IPs seldom fail. What kind of problems are you experiencing?
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
06-20-2014, 10:08 PM #3
Without knowing the symptoms exactly could be anything from bad fuel to dirty junk in the ip to sticking delivery valves, or could be timing, stuff like that
NapaBavarian
06-21-2014, 09:17 PM #4
One car has an idle issue, will start at wide open throttle and after a little warmup it can be run at any normal rpm, but wont idle, foot off throttle, car dies.
Second makes little to no power, I haven't been able to look at it much, but I did change fuel filter. I'd like to tear it appart and replace all fuel lines, I may try a different lift pump too. It seems better once it warms up, but still hardly makes any power.
NapaBavarian
Torkey
Dirty Diesel
220
06-21-2014, 09:54 PM #5
I forget to ask... What year and models are these cars?
And did the problems start suddenly or was it a gradual and progressive type of thing?
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
NapaBavarian
06-22-2014, 01:30 AM #6
The car that dies came as a non runner, I think glow plugs may be dead but so is my multimeter so I cant verify. 87 300sdl
The other is an 82 300sd that started as an intermitant problem uppon startup and gradually became worse.
NapaBavarian
Tito
06-22-2014, 01:39 AM #7
for the one that keeps stalling you can try to turn op the idle. Top external screw on the governor. I don't remember if you should turn it in or out.
Tito
06-23-2014, 09:00 PM #8
The one that has little to no power probably has a clogged ALDA line.
Just had to clean the soot out of my buddies 300SD, it was the slowest thing id ever driven before we fixed the alda
cho
06-24-2014, 01:09 AM #9
the 2 symptoms I have witnessed were
worn DV's - you have to change these, no cleaning helps /significant shakes is the sympt./
messed elements (via upper nuts) - back to adjustment table /no able to start,uneven fuel,severe shakes/
This post was last modified: 06-24-2014, 01:26 AM by cho.
cho
