prechambers mods?
prechambers mods?
hy there,
in my set up i will reopen the holes a bit, from 8 holes at 2,2 mm , i will have 8 X 2,5 mm, the botom one is 1,5mm and will stay the same for the moment. (606.04 pre cups). the pre cups marked 606.02 usually found in N/A engines are 8x2.1mm and botom hole at 1.3 or 1.4. , from this differnce one can understand that increasing fueling , involuntarly needs increasing the holes área or nr of holes etc.
taking acount the laws wich rule flow, increasing the holes beon the área of te neck hole will produce any significant gain, at least thats my bet. since the neck diameter is not more than 10mm (just guessing) i can´t see any gain using a hole wider than 2.50 , to 2,75 mm.
i´m trying the 2.5 mm .
let u know my findings.
any how, would be interesting to know if someone had opened the holes more than 2.5mm with positive results .
regards
