led-panzer's 1984 300D 4-speed
It's unbelievable because if you do the math for a 3L motor with 130cc per injector x 5 cylinders with 3L displacement, and 1.9 bar of boost, with 75% volumetric efficiency, 70% compressor efficiency, 80% intercooler efficiency, you get an air to fuel ratio of 12.9:1, which would mean 12% of your fuel would go out the tailpipe as black smoke, which would be a hell of a lot of smoke. AFR should be 17-18:1 for complete combustion.
The numbers are important in designing a setup to burn a certain fuel amount in a certain motor, which is what both you and I are doing. You need to know how much air you need to burn all the fuel. Then you select a turbo to provide that air amount efficiently at your chosen rpm.
Basically either chemistry and physics are right, or Keino is right and I am making faulty assumptions. But I double checked the math and assumptions with Dougal and bush65 over at 4btswaps. If Keino is correct about boost, and correct about no smoke, then there is no way he is correct about his fueling level.
