02-02-2015, 04:28 PM
#111
(02-02-2015, 03:22 PM)mike-81-240d So does this mean your old Holset is for sale?
Not yet. I want to see how this turbo works out before I get rid of the HE341.
My reasons for trying the HE221:
Looking to move the power down a little lower in the rpm range. I'm also looking for a more "driveable" experience. The 341 is a fun turbo that I know will flow all the air I could ever use, at least until I start bending rods. However it spools HARD.
For example, turn a corner, shift into second and give ~60% throttle. Go from 5psi to 22psi in the matter of a few hundred rpm, breaks back tires loose and/or makes clutch slip.
I think a more linear boost curve will make the power transfer to the ground a little more linear. If that makes sense.
My 6mm pump as it sits now should be 100cc (turned up a little since I first got it, dieselmeken said it would be very easy to get 100cc from it) which is enough for around 250hp at the crank. The HE221 should be well sized for that power, I've seen dyno proof of 285hp at the wheels with one.
7.5mm M-pump, GT3582 turbo, F-Tune Performance intake/exhaust manifolds, A/A intercooler, 315 nozzles, Enlarged prechambers, Bosch 044 feed pump, Custom lightweight flywheel with 240mm clutch, Lowered, 17" AMG rims - 300 hp OM617 project
1985 300D 280,000 miles RIP
