led-panzer's 1984 300D 4-speed
VERY productive day. I abandoned the tank with all the sludge in it, realized I had a perfectly clean tank sitting in the 85. Yanked it out and put it in the 84. The exciting way - with it still 1/3 full of fuel. New tank screen and fuel lines. I was literally covered in diesel.
After getting that together I was still unable to draw any fuel from the tank. The only thing left that hadn't been cleaned out or replaced was the lift pump. Swapped for the 85's and bingo we have fuel. Lift pump probably was the source of the original problem but Im still glad I swapped out that dirty fuel tank.
I redid the front springs and cut another half coil. Fronts are now perfect. Did the rears, and put in new rear shocks and metal sway bar links. Cut 1.5 coils from the rear which is a little too much. I'll have to either put thicker pads in or pound some spring blocks in there to bring it up a little bit.
I got the fuel system primed, battery charged and got it started. I still need to adjust the vertical throttle stop, I think there is a wearing in period with the IP when you make an adjustment. When it first fired up it wouldn't idle, I had backed off the vertical throttle stop 5 turns. Turned it CW till it would idle, return to idle was only slightly slower.
Took it for a drive. I didn't want to push it too hard being I don't have gauges in yet. Definite difference in acceleration and revving. It will shoot right up to 5000 rpm. My 85 you have to ask it politely to go past 3k. Not quite as fast as my Mini but we're getting there.
So once it was warmed up the return to idle began to take longer and longer. So I need to back off the vertical throttle stop some more, and I hope it will idle when I do. If not ill have to pull the pump again and adjust the idle gov.
We're getting there!
