STD Tuning Engine W123 Engine Swap Questions
IsaacDW
Turbo-charged
26
07-18-2009, 12:14 PM #1
I recently found a 1980 200D for sale with a manual transmission. My thinking is to swap the five cylinder turbo from my 300TD for the four cylinder from the 200D. The 200D is a W123 chassis so will the motors bolt to the other car with relative ease? I know that Forced has a 3.0 in his 240D so I'm hoping the same logic will apply to a 200D. I know that an engine swap is no small feat, but will it (for the most part) be a direct swap?
IsaacDW
07-18-2009, 03:11 PM #2
Are you in Europe? If you're in the USA and the W123 200D is functional, it would be much more valuable and rare as-is.
The OM615 is dimensionally the same as a 616 so the swap process would be the same, except a 200D should have a "Gorilla Knob" on the dash (Partially seen in the lower left of the first picture) to control the glowplugs and starter.
This post was last modified: 07-18-2009, 03:13 PM by ForcedInduction.
IsaacDW
Turbo-charged
26
07-18-2009, 03:34 PM #3
I'm in Flint Michigan. The current owner says that it is more of a "project car", so I assume it would take some very significant funds to restore it to "rare classic car status." The guy is asking $600. I was hoping to swap the 617 turbo motor from my parts 300TD and utilize the manual transmission on the 200D. I would put the 615 in the TD so I would be able to move it under its own power, just VERY slowly.
Will the turbo 617 fit into the 200D? The transmissions will fit if I switch the flywheels, right? I seem to remember to hear something about swapping the front springs as well.
What do you think?
IsaacDW
What do you think?
07-18-2009, 04:40 PM #4
It will fit. Its pretty much the same as a 240D swap except for having to deal with the gorilla knob.
The flywheel will be a little light but it will work fine and you'll have to cut the driveshaft 4" shorter as you would with a 240d.
IsaacDW
Turbo-charged
26
07-18-2009, 10:01 PM #5
Will I need to get a driveshaft / axle shop to chop and balance the driveshaft? Will the stock 200D front springs handle the extra load?
IsaacDW
IsaacDW
Turbo-charged
26
07-20-2009, 01:32 PM #6
Since the transmission will be sitting four inches further back, will the shifter linkages/ shifter hole need modification? And the I must wonder about the transmission crossmember.
IsaacDW
07-20-2009, 08:48 PM #7
Search the various forums for swap guides. It has been done many times before and is detailed quite well.
The driveshaft and shifter linkages must be shortened by 4". The crossmember can be modified to work or one from an automatic 240D can have the proper holes drilled into it.
07-21-2009, 04:37 AM #8
(07-20-2009, 08:48 PM)ForcedInduction Search the various forums for swap guides. It has been done many times before and is detailed quite well.
the 240d auto xmember is the right one, no holes required.
07-21-2009, 05:57 AM #9
(07-21-2009, 04:37 AM)winmutt the 240d auto xmember is the right one, no holes required.
Not quite. The holes for the 240D auto and 300D manual are not in the same location.
This is a genuine 300D 4M crossmember, the 240D auto hole locations are marked in red.
07-21-2009, 02:30 PM #10
I'm pretty sure thats why the slots in the middle are so long....
