STD Tuning Drivetrain Difference for 1st/2nd gear take off??
01-06-2014, 11:15 AM #1
Hi!
What part in 722.3xx transmission makes the difference between take-off in 1st or 2nd gear? Is it just the valve body or something else? Resp. could I replace the 722.357 (OM603 turbo) with another 722.3xx and change the valve body to keep 1st gear take-off?
I'm slowly looking for a spares gearbox - if it would be this simple this would be much easyer - as finding low-milage turbo-transmissions is difficult. And I don't want to lose 1st gear start Smile
Thank you!
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Hi!
Thank you!
Duncansport
01-06-2014, 12:34 PM #2
(01-06-2014, 11:15 AM)DiseaselWeasel Hi!
Thank you!
http://www.2phast.com/500e/ <-------- Make your own 1st gear start. there are also modules to do it.
Duncansport
Thank you!
01-07-2014, 01:52 AM #3
Sorry no, not for me...
DiseaselWeasel
mbz123
01-12-2014, 11:43 AM #4
Early 90's c124 had this. Expands your search at least. Unknown would be a gasser trans and differnt shift pts. Info hazy. Dunno, worth a try.
If it wasn't for those @#$% two top bolts I woulda been commenting from the BTDT section. Ran outta time then on next trip... POOF! Thank you, come again.
MBZ123
mbz123
MBZ123
