STD Tuning Engine twin OM617's
twin OM617's
twin OM617's
oel_brenner
10-08-2008, 08:43 PM #1
this is on a few other forums.. and I know its a bit off-topic here but as there are a few 617 fans on this forum
I thought I would share it here as well
the project before my SL300D was this:
<!-- m --><a class="postlink" href="http://www.coastalboatsales.com/jfraley/gallery/scubaboo?page=1">http://www.coastalboatsales.com/jfraley ... boo?page=1</a><!-- m -->
2x OM617's into a 28 foot sportfisherman
nothing superturbo yet.. but I have plans..
video of engines running on page 26
<!-- m --><a class="postlink" href="http://www.coastalboatsales.com/jfraley/gallery/scubaboo?page=26">http://www.coastalboatsales.com/jfraley ... oo?page=26</a><!-- m -->
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
10-11-2008, 03:38 AM #2
That is a very cool project! I'd love to make an H-10 or I-10 setup in a pickup or something.
oel_brenner
10-12-2008, 10:07 AM #3
yeah.. just do it like they do in tractor pulling, tie two engines together
with a big chain Big Grin
cars
trucks
boats
oel_brenner
cars
trucks
boats
Telecommbrkr
Soon to be mod'ing......
97
10-12-2008, 10:55 AM #4
oel_brenner You have done what I have been dreaming of for a couple of years now. Awsome job!!! :mrgreen: Do you have a journal explaining the build pictures? I noticed that you had to replace an engine part way through.
With your planeing issue, these props were the ones used with the 454's? Is it a lack of RPM or HP/Tourque?
Mods are in the works...
Telecommbrkr
oel_brenner
10-12-2008, 01:01 PM #5
Thanks..
I dont really have a journal, just the captions along with the photos.
I did have to replace one engine, broke a timing chain
they are not the original props, I am running much larger/flatter wheels
then the 454's used because of reduced engine RPM and I am running a reduction gear
look around online for a prop calculator that will get you close, then trial and error
these guys have a good prop calc:
<!-- m --><a class="postlink" href="http://boatdiesel.com/">http://boatdiesel.com/</a><!-- m -->
and if you want to do more math and less trial and error get Dave Gerr's book:
<!-- m --><a class="postlink" href="http://www.amazon.com/Propeller-Handbook-Installing-Understanding-Propellers/dp/0071381767/ref=sr_1_14?ie=UTF8&s=books&qid=1223834261&sr=8-14">http://www.amazon.com/Propeller-Handboo ... 61&sr=8-14</a><!-- m -->
it is the absolute reference to the science behind marine props
There is a guy in out in New Orleans who built a downeaster from scratch
and powered it with a single OM617 and has had pretty good success
cars
trucks
boats
oel_brenner
Thanks..
cars
trucks
boats
oel_brenner
08-07-2010, 09:07 PM #6
some videos of my boat running for all you OM617 heads out there..
http://www.youtube.com/watch?v=n4XzRJ0hTGs
http://www.youtube.com/watch?v=UqbRMGi72CM
cars
trucks
boats
oel_brenner
cars
trucks
boats
08-08-2010, 12:21 AM #7
sweet that looks like fun!
yankneck696
Build it so strong &amp; blow it up good !!!
395
08-08-2010, 04:42 PM #8
Ole Brenner, I contacted you a while back about your adapter plate on another forum. I now have a 1975 23' Penn Yan Tunnel drive with reverse rotation. (Right hand). Did you get a reversing trans for one of your engines & what ratio & make? As I can only fit a 12-13" prop in the tunnel, the prop will have to be super custom if I go for a 1:5 ratio. All of the PY's have the 1:1 VD trans. Any details will be greatly appreciated, as I am going back to work at the boat yard (Melbourne, FL) & will have access to the Lathe, overhead, plasma, TIG & MIG. Were you ever able to find the measurements on the plate? Also, are you just running both LH rotation? Glad to see you on this board, as it's somewhat kinder than the others. Ed
yankneck696
oel_brenner
08-08-2010, 05:39 PM #9
(08-08-2010, 04:42 PM)yankneck696 Ole Brenner, I contacted you a while back about your adapter plate on another forum. I now have a 1975 23' Penn Yan Tunnel drive with reverse rotation. (Right hand). Did you get a reversing trans for one of your engines & what ratio & make? As I can only fit a 12-13" prop in the tunnel, the prop will have to be super custom if I go for a 1:5 ratio. All of the PY's have the 1:1 VD trans. Any details will be greatly appreciated, as I am going back to work at the boat yard (Melbourne, FL) & will have access to the Lathe, overhead, plasma, TIG & MIG. Were you ever able to find the measurements on the plate? Also, are you just running both LH rotation? Glad to see you on this board, as it's somewhat kinder than the others. Ed
I am running a ZF 1.25 ratio marine gear, and I run counter rotating props
Both engines rotate the same direction, but the ZF gear flips rotation on the STBD side
I am running 16" props, thru reduction gear, so if you can only fit 13" prop on your boat, you are probably going to have to stay with a 1:1 ratio, and may have to go to four blades to keep RPM under control.
cars
trucks
boats
oel_brenner
cars
trucks
boats
yankneck696
395
08-08-2010, 06:20 PM #10
Yeah, that ZF gear is a bit pricey, but with going back to work at the boatyard, I may stumble across something. I thought about just running in reverse with the VD, but there's a reliability issue there. Thalks, Ole...
yankneck696
