Old Rajay Turbo Kit 240d
So now all you need is an IP from a Cummins 4BT, 617 turbo pistons/rods, 617 turbo oil pump, some tweaking of the block to install piston oil squirters, and a VGT and you have a superturbo 616! Might also need a custom camshaft and a bigger crank.
EDIT: Probably a good idea to lower the compression a bit too with a spacer or something..
