(06-22-2009, 05:57 PM)willbhere4u I got an oil filter housing off a 617 turbo for my oil supply to the turbo
all you need to get that working is to swap the back plate off the donor to the filter housing on your car... I accidentally grabbed a N/A engine's oil filter housing (i think thats the same as the 240s) when I was powdercoating a bunch of stuff and didnt realize the oil lines came off of it... anyway, I just swapped the back plate over and installed it... you might wanna swap it over anyway since the filter housing does tend to leak after 20+ years...
W123 Mods: 4 speed ** manual climate control ** '85 Kalitucky intake ** manual windows & full tint ** Euro headlights retrofit w/bixenon projectors ** 4 brake light mod ** Vogtland 50mm drop front & Lesjofors S600 drop rear springs ** 16" rims ** late w126 brake spindles, rotors & calipers ** full suspension rehab ** Bilstein HDs ** AL129X alternator & 1/0 starter and charging cables ** 300GD clutch/flywheel ** AFCO 80103N radiator & Earl's 41610 oil cooler ** custom block-off plate, remote oil filter & t-stat ** MW IP w/ tomnik's 6.5mm 'Holly' elements **
S124 Mods: 400E Rear subframe ** SL600 Brakes ** Late 300E 210mm diff ** SLK230 6 speed ** 17" CLK rims ** Vented RF Fender ** Facelift Hood, Headlights, and Lower Cladding **
OBK# 62
