Om605 compound turbo build, my Corolla Ke70 tracktoy
(07-10-2014, 11:28 AM)raysorenson Strictly speaking of theory, an increase in volumetric efficiency often requires retarded combustion.
(07-10-2014, 01:47 PM)MFSuper90(07-09-2014, 08:01 PM)Stamsaas The camshafts have been set up by KM Cams, it is the pump timing that i Wonder about. Someone here must have swaped cams before??
Are we talking about the injection pump cam?
So are you wondering if you should change timing since you got a different cam?
(07-10-2014, 01:59 PM)winmutt 717.430 trans?I had 717.435 but the 3.gear didnt take it when I tried to turn rubber Now I put in a 717.411 gearbox I have also got a Tilton clutch valve now, and this will make the gearbox life better
