Om605 compound turbo build, my Corolla Ke70 tracktoy
(12-08-2013, 07:25 AM)erling66(12-08-2013, 06:19 AM)Stamsaas I have a gearbox ready to put in, so start With that. But interresting what you say about put a bearing in the flywheel Must check my flywheel (lightwight) to see if i can put a bearing in that. Is it the same splines on the gearbox shaft?The axle has the same splines but is 2 cm shorter so it will not reach your clutch plate, unless you have a clutch plate with a 2cm offset center. But you probably don't since it fit your long axle 5 speed.
You should adjust the fuel delivered before boost, ask Gøran if you are not sure how to do it. A tuned diesel that make that much smoke gives old diesels a bad reputation. Imagine if one of the politicians so your video I am afraid to think about the consequences....
