5 speed manual om617
(11-01-2013, 11:24 AM)Jooseppi Luna(08-27-2013, 03:28 PM)5spd617 it is really nice to have the overdrive with the 2.88 rear end. haha. 80 mph at ~2500 rpm
really good mileage on the freeway about 30 mpg.
after getting a good flex joint and good bolts i haven't had any issues.
What speed do you get 30 MPG at? 80 MPH? 30 MPG @ 80 MPH in a luxury barge would be awesome and makes me wonder what kind of mileage I could achieve at lower speeds... 35 MPG? That would be awesome. I remember that Doktor Bert on PeachParts said that he could hit 35-37 MPG doing 60 MPH in his W116 'SD with automatic after he swapped in a 2.47:1 differential.
A few questions on the swap:
1) Is the 5-speed shorter than the auto or is it the other way around? What is the difference in length? Did you end up needing to modify the driveshaft?
2) What did you use for a shifter? The W201 shifter?
3) What did you do about the shifter linkages?
4) Did you ever end up covering the starter hole with anything?
