STD Tuning Engine super smoking om601
super smoking om601
super smoking om601
01-06-2013, 09:30 PM #1
Looked at a w201 190D 2.2 just now that has crazy smoke coming from the exhaust, like it smoked up the whole block in about 5 minutes. Is it worth buying? Its got a 5 speed and a clean body. Anybody know how difficult it would be to rwbuold a 601? Thanks guys
01-06-2013, 09:54 PM #2
Define worth. I'd pay $400 for it, if I had time to deal with engine swapping.
01-06-2013, 09:57 PM #3
It also had an occasional knocking in the front of the engine, I wonder if it all might be a problem with the vacuum pump?
01-07-2013, 07:51 AM #4
What did the smoke smell like?
pmj4147
T04R + TD06
42
01-07-2013, 10:20 AM #5
if the issue is the headgasket
i'll buy it
but something else..?????????????
(like cylinder scratch...etc)
never ever.
pmj4147
i'll buy it
never ever.
01-07-2013, 11:09 AM #6
Buy it cheeeeep. Smoke is oil/coolant consumption. vac pump, HG, injectors, rings, or a holed piston. How much power does it have? probably worth it if under 500
01-07-2013, 03:28 PM #7
It was definitely oil smoke, and since it was constant it leads me to believe its either sucking it into the intake somewhere. Hmm, so how does oil get straight into the intake, or straight into the exhaust? The engine seemed smooth otherwise, except for the occasional knock coming from the front of the engine. Vacuum pump? Apparently all of this started right after he changed the oil
01-07-2013, 04:41 PM #8
(01-07-2013, 03:28 PM)sassparilla_kid Apparently all of this started right after he changed the oil
bullshit.
Agree on a price before you play with it. If you can make it not smoke you don't want him upping the price.
Pull the VP and run it-if it doesn't smoke there you go
bullshit.
01-07-2013, 09:05 PM #9
The car is two hours away and I work 6 days a week so I cant be going back and forth trying to fix it before buying. I think I might buy it anyway, since I almost bought one a month ago for close to $3k and this is way cheaper. So if I can't fix it, I can always buy another 601, or maybe turbo 602
