Manual Transmission information
thanks aaa , ill look further as i clean more , i have to stop taking it apart before i find a source for parts .
i will say it looks identical to the second picture on the first post of this thread " slope back iron body" . i can tell it was painted grey"the gear box" and the little bump has red paint ?
i searched against the part number from the case , and it seems to be from a 115 body ? or a 300g . although the info seems that the second set of number under the (115-261-27-01) 28E-9 , is different on trannys in the G.? all second hand info .
also i have i a little bit of vertical play on the input and output shaft , les when any gears are engaged . what is acceptable play ?
