Improving my W124's handling
Just buy coil overs with the adjustable rear spring perch. You can get proper spring rate by design and set ride height as you wish. I use to mess with all this a long time ago when there were not products on the market but you can buy a pretty nice coil over frt and adjustable rear setup fro around 1500.00 or less.
Sway bars, sway bars, sway bars are the biggest change in handling in these cars. Especially the rear. Get at least the 500e stuff. There are some people doing limited production runs of slightly stiffer stuff.
On the rear end if you lower to much you will wear tires. If you start to make changes to fix that then you need to do the whole thing or you will induce horrible bump steer. Setting up the rear end after you put all adjustable arms on is a big undertaking.
