Delivery valve socket?
This is probably a longshot...
Is anyone here in Reno and, if so, do you have a the special splinned socket for removing the delivery valve holders on the OM603? Could I borrow/buy it from you?
I haven't checked out prices online but its probably more than I want to pay for a one time use thing. Also I'd like to get it sooner rather than later.
Also Im replacing a leaking power steering fluid return hose. The only hose ive been able to find here is a non-wrapped hose 10mm made by Parker rated to 350 psi and the guy told me it is rated to 250 degrees F. Will it work? The fluid shouldn't make it disintegrate eh?
Cheers dieselheads!
