Gearbox Controller 722.6 ver 2
(02-21-2017, 02:19 PM)jupelHi(02-18-2017, 12:07 PM)olefejer(02-18-2017, 08:37 AM)jupel Hi Ole! Is it possible, to take signal from abs on old revision controller? I try to make it, but it work unstable, and as i see the signal from abs sensor must be divided by 3? Can you help to solve it?
Hi
Yes no-matter how old the controller is you can connect it to ABS, sensor
But correct the newest ones has a real automotive ABS sensor chip that is used for both external Speed and RPM, that is more immune to noise then the older type.
If the speed show 3 times to much, you goto
"Setup Parameters" -> "External speed %" standart is 100 set it to 33
Then test and see if it fits,
thanks, i've got a lost connection, and fix it
and one more question: how about firmware update for old version with lcd displays and led gear indicator? it would be nice to have voltage relate firmness. Because i'm not want to have oled gear indicator in old car, in w124 is bad look. and install display in ashtray, look nice.
and how about trans lock setting, i want to set speed for each gear separately, is it possible?
Hi
