Gearbox Controller 722.6 ver 2
Thank you for explaining but that's not really what I meant. I understand all what you say but If I soon run 1000nm through 320cdi box then what parameters or pressures in menu I should change to make box shift as hard as possible with full throttle? For example if I drag race, I only mean 100% Load. Is it helpful if I change that 100% Load fine tuning from 0% to the highest %? I want to make sure that controller is not limiting shift pressure or modulating pressure on 100% Load when shifting and gearbox is really working on its limit.
