Gearbox Controller 722.6 ver 2
Yes correct it is a LOGIC problem,
As when the car is stationary, the N -> D is handlet one way, even the 3-4 shift valve is used to give smoother "Garage Shift",
Also a check regarding if it is, first or Second gear we have first time in "D" if second gear it is corrected. to first.
Also as the Controller can run width no external speed sensor it is Essential that i know what gear we are in, to calculate speed correct. if you move to N i am lost.
Well anything can be fixed it is but it would be a rather big effort width not that big of an advantage.
But ok i can follow you if someone is used to push in N when running down hill i can see it is irritating
