Gearbox Controller 722.6 ver 2
(06-02-2012, 04:44 PM)olefejer Hi
Just to let you know that i have made a new version of my gearbox controller for the 722.6 gearbox. if sombody want to use this box in older cars. and enjoy the overdrive and lockup.
Gearbox feature
Full automatic mode
Manuel mode by the little joystick
Manuel mode width Paddle (one wire true steering column).
Fully adjustable shift hardness and speed.
As it is a diesel forum the controller can also do different thing.
1. Build in BOOST controller through electronic Vacuum valve.
2. Build in VGT BOOST controller through electronic Vacuum valve. (Need EGP signal)
3. It can also adjust the idle of a Manuel OM603 pump,
4. It has input for EGT K typ sensor.
Some thoughts.
As i have build some extra output in it can also do other things depending on the input.
Input is (TPS, BOOST, EGP, EGT, KM, RPM,)
Iam open for any suggestion you can think of. ???
http://www.youtube.com/watch?v=DLmaMMUfx...=g-all-lik
(01-17-2013, 11:10 AM)hean500e Hej Ole.
Lyder spændende det du har gang i..
Jeg har lige et par spørgsmål som jeg håber du vil svare på..
Jeg har en Mercedes W124 500E årgang 1992 som jeg er ved at istansætte totalt.
er ved at finde en 6,0 AMG motor som jeg skal ha' lagt i, og vil meget gerne have en nyere 5 trins gerkasse sat i, men har altid hørt at det var umuligt, vil du mene at det vil kunne lade sig gøre med min bil??
Håber at høre fra dig..
Mvh.
Henrik Andersen.
Gearbox feature
Full automatic mode
Some thoughts.
Hej Ole.
Mvh.
Henrik Andersen.
Gearbox feature
Full automatic mode
Some thoughts.
Mvh.
Henrik Andersen.
Gearbox feature
Full automatic mode
Some thoughts.
