602 crank in 605 ?
602 crank in 605 ?
(05-21-2012, 03:45 PM)bad3gakk Is it possible to use a 602 crank, in my 605, with 606.960 rods and pistons?Hi. Yes you can use 602 crank on 605.
Will the rods and the crank fit?
Some 605's have a 602 series crank, and some 605... do u know if there is differences in bearings? I planned to use 606.96x pistons and rods..
This is going to be molested by a 8mm herlevi monster IP, so i'd like it to last a little longer than the previous
Im pulling the engine to pieces, and putting a new MLS head gasket, and hopefully studs or 12.9 bolts in.. Any tips? Trying to make better precausions this time, needless to say where my last engine wendt...
I had old previous setup also 606 pistons and rods with 602N/A cam
What i have measured those parts all dimensions are the same
