STD Tuning Suspension Rear hydraulic system
Robert_UAH
04-17-2012, 01:24 PM #1
What is required to convert from the rear hydraulic suspension on a W123?
Robert_UAH
04-17-2012, 01:58 PM #2
You will need to weld in some kind of spring perches. I don't know if the SLS has springs or not from the factory
04-17-2012, 03:56 PM #3
You need replacement springs and shocks. The stock springs will sag without the hydraulics supporting them.
http://slsconversion.com/
Robert_UAH
04-19-2012, 08:58 AM #4
So I just need some springs and Bilstein HD shocks. No need for different spring perches or anything?
Robert_UAH
propigskinSLS
06-05-2012, 04:41 AM #5
(04-19-2012, 08:58 AM)Robert_UAH So I just need some springs and Bilstein HD shocks. No need for different spring perches or anything?
No spring purch change or modifications required:
You can order my springs at www.slsconversion.com
I also sell stock type shocks that bolt right in and a sls pump block off plate.
You can use Bilstein shocks also off a w123 300D sedan that bolt right in if you want the best shocks....
Thanks,
Erik
This post was last modified: 06-05-2012, 04:41 AM by propigskinSLS.
propigskinSLS
Thanks,
Erik
